Discuss Flue termination in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Davinder
Flue terminating into internal space
Just need to pick your brains for a moment guys/girls.
Now this flue (For an Ideal Iasr 24 HE) Terminates into an internal space (some sort of out-building/Lean-to), So we've ID the boiler.
Now we're a bit stumped about how to re-run the flue so that it terminates safely.
Here’s a Picture of what I’m talking about:
It's been suggested to us that we could just put a plume kit on it, but I thought that you can't use one of those as a solution to a terminal position problem, (there just to 'manage the plume' so that it doesn’t cause a nuisance to, - say your neighbour). Correct me if I’m wrong.
Also in different properties I’ve seen (where they've had a similar problem) they use a normal horizontal flue kit, but put an elbow on the end and continue the flue run vertically, till they get to the end and put another elbow on with the terminal off-cut from the horizontal flue kit.
What would you suggest, because I’m not sure what the best thing would be to do here?
Plus (this may or may not make a difference), it's 650mm away from a internal corner.
Reply to Flue termination in the Plumbing Jobs | The Job-board area at PlumbersForums.net
