Hi all
been to a apartment today and the. Boiler is twin flued it goes above the ceiling and under the floorboards of the apartment above about 7 meters to the outside, both flues for the boiler come out about an inch from each other. Obviously you can't get your head up to look at the full flu length so where do the inspection hatches need to go? Is it near every possible joint or at sections to see the whole of the flu? Even if I put the hatches in they will be on the plasterboard ceiling and look stupid but you won't get your head up as the floorboards are there so do you just use a small mirror to check.
I normally work on standard flus so just looking for some advice from you guys that come across this more often.
Cheers Martyn.
Cheers Martyn.
