Discuss flux brushes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Do most people tend to use pastry.brushes as flux brushes? The flux brushes I get from the plumbers merchants dont last long
As said eBay
But if your using everflux that heats them
Tape up the metal bit
cleans your fingers
I use a half inch paintbrush.. just trim to suit and buy plenty
I've had the same small laco flux pot with brush on the lid for about 3/4 years, just keep topping it up with flux from a big tub. I don't clean fittings with flux after soldering like some of the lads at work do so maybe that's why it's lasted so long
this fad for 'cleaning up' the joints after soldering by brushing flux on em drives me crazy.
I maybe wrong but doesnt it help clean the joint up before you clean it ?
clean yes..
with flux ? no, it only goes green and eats away at the pipe over time.
solder, swipe your finger around the joint, clean up with a wet cloth and done.
why does a joint need more flux after its soldered ?
I've always used my fingers, doesnt waste flux and the brush's are rubbish and end up lost broken or full of dust,
I always used to use my finger to apply flux, stopped doing that after reading how nasty flux is, I now try to not breathe the fumes in too but not always possible...
Not sure of the brand, but I just use the couple of freebie brushes I blag off the merchant whenever I buy solder ;)
They almost always last a roll, only time they don't is when I've had a spell of not soldering and they're left dirty and unused for too long, the bristles just clump up and drop off if left fluxed up too long.
Tbh i've never used a brush for flux. Always my finger or the end of the solder and i'm still alive and have silky smooth skin so the wife says ;)
I do the same. My flux and brush stay clean and the small tub is a good size for the tool box. As a couple of other people have mentioned, this pasting flux all over the outside of the fitting drives me crazy too. About half the apprentices at the college I work in do this and I wonder where the idea started? It really winds me up much more than it should, especially when a nice tub of flux is full of bits of melted brush which can cause a bad joint if you don't notice it before you assemble the fitting.
Stop it!
Same here. I'm kinda of getting a taste for it now too!
Whats wrong with cleaning the pipe up with it after soldering? It makes it bright and shiny, looks a good job when finished. I always do it and then wipe the pipe over with a damp cloth.
Plumb center flux brushes I use, PTS ones are rubish n don't last long. I clean the fitting with flux afterwards then wipe clean with a damp cloth. Applying more flux to the join helps the solder run around the joint also. I use end feed fittings.
Never have green flux marks left on my pipe
Never have green flux marks left on my pipe ��
So you wipe the fitting with your flux brush after soldering before the solder has set to aid the solder running? I used to do this but was burning the bristles on the flux brush
I do it and very rarely get leaks, the Plumb center brushes are good quality and last long enough and I use them very day.
the only thing I go in plumb centre for...brushes and there jet blue paste
Your all doing it wrong have a search on ebay for hog hair brushes, 1 brush will last months and thats even applying flux to fitting straight after soldering.
Do most people wipe fittings with flux after soldering as its still setting?
I haven't seen it in any of the soldering guides I've read and I don't feel the need to do it myself but suppose the end result is the most important thing. If it's sound and neat then I suppose it doesn't matter how you get there. I don't like doing it though. A waste of flux in my opinion and I get good results without doing that so I'm not about to start.
Reply to flux brushes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Did anyone watch Britain's Got Talent last night? There was a Plumber on from Stockport called Darren who bottled it last year but did his...
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form...
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
