H
Hannah
So am really confused about what's the difference between flux's :mad2:
Can anybody tell me? :smiley2:
Hannah x
Hannah x
Discuss Flux in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hannah x
I really don't give a flux.
from memory fluxs that are only active when heated should be used on gas pipe work as unable to flush wether laco or powerflux are I have no idea can anyone advise
LaCo for me but everything works. No need to clean the fitting with LaCo imho
Have u ever had Yorkshire fittings get flux bound. Flux it all up and assemble, but one fitting won't rotate or come off? It was fine before flux too!!!!!! End up with hands covered in flux and slipping all over?
if lead free solder gets anymore expensive we would never use leaded on cold water would we :thinking:.its like everything else in this country - they want use to eat healthy but chips are cheaper than a salad -they want us to use leadfree but its nearly 3 times more expensive its madhannah, dont worry, you will get used to the whichever one you use at college and probably just stick with that, or you will find an employer and use what he/she does.
something to bear in mind though with rising solder prices is that more plumbers are using the cheaper leaded solder on all non-potable applications powerflow flux (the yellow tubs) is specifically for lead free solder as it is allegedly to aggressively corrosive for leaded solder
Are there any fluxes that wont turn your fingers green?
NOKORODE® Regular Paste Flux » RectorSeal
been using this a year, wouldnt go back to laco or pwerwhatever again, its clean, doesnt hurt cuts and doesnt green up the copper, wipes clean no brainer imho
Reply to Flux in the Plumbing Jobs | The Job-board area at PlumbersForums.net
