Discuss forum rules..... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Yes it does can you touch the gas valve if yes you need to be gas safe but then you would need to remove the case so you would need to be gas safe just incase it doesn't have a secondary door/ seal
Stop digging a hole to Australia
I'm glad we have established that a blanket statement of having to be GSR to remove any boiler cover is completely wrong :hurray:
I think we gonna miss the Olympics...
I'm not digging holes shaun...it was you that gave the wrong info stating you have to be GSR to remove a boiler cover which we have now established is not as black and white as you first thought/portrayed :wink_smile:
I wrote the forum rules. Which part do you think you know better than me?
The information ShaunCorbs gave is correct. You, however, are wrong.
Want to keep digging?
See if I can put it in terms you can understand
Legally for someone else eg paying job
Non part p / 17th ed3 person
Wants to run a new shower feed from dis board to bathroom and install new pull cord and new elec shower etc can he
No he can't as its classed as notifiable needs certification etc
No that's not correct either Shaun. As long as they are competent to do so and either have it tested an notified using a third party who is either registered with napit or stroma or contact LABC before hand a they send one of their registered contractors to carry out the necessary tests and inspection (for a fee of course) then they are well within their right to install the circuit.
No ban hammer yet. What you need to understand is that we take a wide and sweeping view with regards the removal of boiler cases, decorative or otherwise.
If you are not gas safe you do not do it.
THOSE ARE THE RULES OF THIS FORUM.
Your opinion doesn't matter on the subject. There are far too many manufacturers and models to start saying you can remove this one, but not that one or that one.
Now, you may disagree. That's your right. But you will respect the rules and abide by them, as you agreed to when you signed up to the forum.
Otherwise I will exercise the bit that says the mods decision is final.
Capiche?
part 2 definitions bs7671.Please define competent
haha capiche.... I'm an expert on legalese if you need help with the forum rules?
Yes but if you look at theThink you need a revisit as if I remember right competent person has been replace with skilled/ qualified person
Side note good look getting a spark to sign any diyers/ not skilled work off,
Be like us signing a landlord who fitted his own boiler off
How about no. I'm fairly adept at reading and, much more importantly, understanding legal documentation.
definition of competent person in part 2 it leads you to the relevant parts such as skilled, instructed and ordinary persons as defined. I would never sign off a diy'ers work in a million years but there are schemes out there such as Napit and Stroma that offer this as an add on to your registration.....I don't agree with it but it exists.
This is what I read/ interpreted
Definitions will be expanded and modified. For example, the definition for ‘skilled and instructed persons’ will be changed. It was also decided that the definition for a ‘competent person’ should be removed, to avoid confusion, as it was considered that some overlap existed between the definition of ‘skilled person’ and ‘competent person’.
It was proposed to modify the definition of ‘skilled person’ to align this definition with that of the IEV (International Electrotechnical Vocabulary). The Committee also proposed to modify the definition of ‘instructed person’ for the same purpose.
These changes will be reflected throughout the wiring regulations. For example, Regulation 134.1.1 has been changed from:
"Good workmanship by competent persons or persons under their supervision and proper materials shall be used in the erection of the electrical installation. Electrical equipment shall be installed in accordance with the instructions provided by the manufacturer of the equipment."
to:
"Good workmanship by skilled (electrically) or instructed (electrically) persons and proper materials shall be used in the erection of the electrical installation. The installation of electrical equipment shall take account of manufacturers’ instructions."
Direct from iet
Reply to forum rules..... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
