Discuss Freezing plastic micro bore 10mm pipe in the USA area at PlumbersForums.net
SMB
I need to remove a radiator fed by 10mm plastic barrier pipe, in a pressurised central heating system. I can get under the floor to the pipes.
Is it OK to freeze the pipe so that it can be capped, so that I don’t have to drain down?
Thanks.
RB
As above take pressure off turn both valves off and do one at a time into a bucket and pushfit caps and inserts
but yes you can freeze it just allow 5 mins more time
Reply to Freezing plastic micro bore 10mm pipe in the USA area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
