Discuss Fridge filter connection adapter in the DIY Plumbing Forum area at PlumbersForums.net
I would like to connect up water supply to fridge.
Behind the fridge there is 15mm isolation valve installed however filter connector has got bigger size.
I assume I need some kind of adaptor from smaller to larger size.
Could someone advise what exactly do I need please?
Washing machine valve
Or screw on something like this (looks like it might need a washer!)
or screwfix version needing ptfe tape when you screw it on existing fitting
https://www.NoLinkingToThis/p/flomasta-bush-3-4-x-1-2-/98427
Reply to Fridge filter connection adapter in the DIY Plumbing Forum area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Sonya K
