Discuss Fridge freezer help - connecting to water supply in the Plumbing Jobs | The Job-board area at PlumbersForums.net
U
Unregistered
I wondered if anyone can help me please. I recently bought a fridge second hand and I am having trouble attaching it to the water mains. I have included pictures below (If the link works!). I think it is an american fridge.
http://*********/zVQtdWA.jpg
Brand: RCA
Model: RCG20IERFBB
I have tried looking for a manual online but I can't seem to find one.
http://*********/cppDFGg.jpg
Above: This picture shows the attachment to the fridge. As you can see the pipe fits onto the attachment but it looks like there should be something which screws over the top of it to clamp it on.
http://*********/1RT6CWh.jpg
Above: This is the attachment to the main water pipe - 25mm diameter (sorry about pic sizes). I do not know what converter is needed to connect to our flexible piping.
Any advice that anyone can give would be fantastic.
Many thanks.
Richard
Please register with us to receive an answer to your question.
Reply to Fridge freezer help - connecting to water supply in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Hi, can anybody help, I am able to use my cold water supply to my boiler to also be used to plumb in my fridge and washing machine, thanks in advance
We have a utility room with a washing machine but no sink. Wife wants sink. There is room to fit one and the waste will connect to wahing machine...
Hi I have a 22mm hot and cold water supply to new bath. The pipes finish with compression valves. I need a 500 mm tap connector hose to connect...
hi all, i need help to fix the leak from a pipe connected to the water pump via flexi pipe and it is feed from the immersion heater. I have...
A simple procedure has turned difficult. I am trying to disconnect a floor-mounted bidet so I can change the click clack waste. All is...
