Discuss funny tasting / coloured water problem! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
CXR100
went to a house today to a compliant "water is cloudish and tastes funny , but only when we use the hot tap, the cold is fine , when we run the bath the water stinks and is always off coloured, father in law reckons its the smell of flux but we havent had any plumbing work undertaken in the house recently" i thought to start off with that it could be heating water contaminating the hot water through heat exchanger (maby a pinhole type thing) of the worcester combi (gas) . now i am not gs registered, so shoud i pass it on to another plumber or can any of you think what else it could be?? but wouldent the cold water pressure push into the heating side and blow out of the prv?? this wasnt happening and the heating pressure on the boiler was 1barthis brings me to another point, i have done gas in collage, but work wont register me under their gs , is it legal for me to top up boiler pressure or drain thru the prv if i can open it without taking boiler cover off????? sorry for the long post folks!!!!! :)
Why are they drinking hot water?
tell them to sort there lives out.
The off colour could be oxygen bubbles. Is it ran off a combi?
haha i was thinking excacly the same!!! they are afraids the kids will "drink" it in the bath!! no its defo not bubbles, this suerly would be the same in the cold taps and the houses net door would it?? this sometimes happens in our house after water board have been working on the main! yes its a combi!
if you run a cup of th water into a pint glass and leave it settle for a few minutes and it runs clear its just the water passing through the boiler making it like that.
yes i understand this but why is it tasting funny and stinking?
CXR100 ... Is it a tap used often? I remember a post a while back and there's bacteria that can occupy hot water pipes one of the bi-products is a 'smell. from the gas they produce!!
Check out this article and maybe do a search on smelly water...? Solving rotten-egg odor in water heaters
One thing you could advise if it's a combi is run the tap real slow with the hot water stat turned onto maximum ... that'll kill off most germs I'd imagine :)
so ther is no way the heating water could contaminate the hot in a combi? no point in me rederecting the call to a boiler engineer?
Not unless the system pressure was higher than the mains pressure ... :)
Reply to funny tasting / coloured water problem! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have just had a boiler, hot water tank and power shower pump replaced on advice by my plumber. I have two separate boilers, heat/hotwater...
the pressure of my boiler looks unstable After i re-pressurize to 1.5 bar, using tap is ok without problem. but when turn on the central heating...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer...
Hi there, I’m hoping someone can help me with this problem please. I’ve searched for similar posts but not found anything helpful! My mum’s...
Hi all, thanks for adding me. My Veissmann v50 combi gas boiler has recently started to supply only lukewarm water to the bathroom above it. This...
