Discuss Futureproofing UFH zones worth it, plus advice? in the Plumbing Zone area at PlumbersForums.net
Hello all,
DIY non-expert here, please be gentle.
I'm about to purchase an underfloor heating kit to be installed in our kitchen (total area 9.5sqm, less if not under units, so a small area!). Obviously this would be a single zone system, so a simple purchase.
However, where I'm uncertain is whether to try and futureproof my purchase should I want to extend the piping to the room next door (dining room) at a future point. The kitchen will have a concrete subfloor, but the dining room is a suspended timber floor, which unfortunately I actually installed not so long ago with a failure of forward planning. I don't have the budget to get our builder/plumber to lift the floorboards and extend the system right now, but I figure that it wouldn't be too hard to do in future, with the between joists tray type install.
Should I purchase a 2 zone manifold now, and get the plumber to route some blanked off piping towards the dining room to future proof it, or is that a pointless idea?
Also, my boiler is in the loft. Should I put the pump up there, or put it in the kitchen under the sink/behind a future cupboard location somewhere?
A final question is on brand - I am looking at the Prowarm kits from The Underfloor Heating Store (Travis Perkins spinoff), or those available on theunderfloorheatingwarehouse website. Has anyone got any thoughts on those two options in terms of quality and ease of installation?
Thank you in advance for your help and advice. I am nervous about shelling out lots of money (for me at least) on this so want to get it right.
Thanks . Ed
The prowarm kits are good value for money, I have used on single room and whole house installations (the largest had 12 circuits and 900 meters of pipe)
If you think there is a real possibility of extending it into the dinning room then fit a 2 zone kit.
I wouldn't fit a UFH to a ventilated suspended floor though, UFH works best with concrete screed as it's the thermal mass which makes UFH work best.
Fit the manifold down stairs if possible but you will need a dedicated circuit to the manifold from your boiler.
Under no circumstances should the manifold be pipped off the old radiator pipework! (I went out to a DIY install to find they had just taken the flow and return off the lounge radiator to serve the conservatory UFH )
Call underfloor heating superstore and talk it through with them, I have always found them very helpful.
If you are undertaking the work yourself ensure you pressure the pipework as per the instructions, I have seen several installations with flow issues due to this important step not being followed.
Hope the above helps.
Matt
Reply to Futureproofing UFH zones worth it, plus advice? in the Plumbing Zone area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the sink, dishwasher, washing machine etc. When I pour the concrete there won't be any chance to dig it up anymore. From my own research I get the...
