Discuss Gas books in the Plumbing Jobs | The Job-board area at PlumbersForums.net
wanttolearn
I am going to do my gas course after Christmas but was just wondering what books are good to start learning. As I want to start reading up now to give it time to sink on.
Where is a good place to book your gas course in south wales?
As above and the GATC in Treforest is quite near to you
Not sure if there's anything in Mid Glam college
Thanks a lot guys I was looking into GATC the other day. I've heard they are not the cheapest but the teach you well which is what you want really.
Think I will ring them soon
I can recommend GATC, been there for various courses. The biggest problem you normally have is finding someone to help you gain the experience for a portfolio.
At the moment I'm ok with that as im working with a gas enginerer and he wants me to do my gas. So now it's just save the money
Evening, I had the viper books to use on my ACS initial course in September but ended up buying the Domestic Gas NICEIC books. Similar to Viper but I found that these books had more depth. Recommended by the course tutors. Best of luck.
https://shop.citb.co.uk/CHOSG1.aspx
Reply to Gas books in the Plumbing Jobs | The Job-board area at PlumbersForums.net
