Discuss Gas Burner Pressure Tolerances in the Plumbing Jobs | The Job-board area at PlumbersForums.net
richard978
Mental block, can't remember the tolerances for burner pressures......I was sure it was no more than 5% over and 10% under.....can anyone remember.
Boiler instructions don't specify.
Reply to Gas Burner Pressure Tolerances in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am troubleshooting a gas hob where one burner is reluctant to light. When it is lit and I blow the flame out the FSD on that burner cuts off...
Hi, Non-professional / knowledgeable person here. I'm a Brit in Romania who volunteers for a charity building an old peoples home for needy old...
Hi all, Just a quick question. I have a log burner and a gas boiler on a dual fuel system (Central heating and Hot Water) either can do both. The...
British Gas servicing the above boiler ramped up the boiler to maximum in the installer menu to do flue gas analysis. They also measured the...
Hi, I am trying to increase the pressure in my gas boiler and was under the assumption it just involved opening these two small black valves. I...
