Discuss gas pipe work in brick wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
There is no problem with pipework buried in a wall like that as long as it is fully covered up as with dry lined walls(pipes should also be covered in closure tape to protect from corsion)
not covered , i refused to pipe gas hob in unless they allowed me to trace pipework and alter so it came in front of wall,i'm just verifing i was correct in this course of actionThere is no problem with pipework buried in a wall like that as long as it is fully covered up as with dry lined walls(pipes should also be covered in closure tape to protect from corsion)
closure plate tape/ duct tape is not allowed its fibrous and breaks down,electrical pvc tape does not
a 50mm wide roll of insulation tape is alot cheaper than closure/duct tape so you will save money.
i use them all mate and never seen itall plumbing merchants should sell it. just say you want a roll of yellow tape and they will likely know what you want.
if its corroded its ID, if it isnt corroded it must "AT RISK" of corroding so it must be ??:yesnod:
corroded pipe work isnt ID is it, it would be if it was leaking? i wasnt taught that. ID applies only to a situation that is ID therefor Gas Leak or Fume Leak, a corroded pipe would be classed as AT RISK???
Reply to gas pipe work in brick wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
