Discuss Gas Pressures. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
oz-plumber
Subscribed
Just out of interest;
What gas pressure do you guys run at from the property side of the meter?
Oz-plumber
Thanks,
We work on 1.1 kPa - 11 mbar.
Quite low compared to you guys.
Oz
We are on natural gas.
Its been a bone of contention over here for as long as I can remember our gas pressures.
We have to run such large gas pipes on jobs due to the low pressure.
Its not unusual for us to run 50mm or 65mm gas supply from the meter to service larger domestic houses.
Have had a couple of jobs where we have had to start at the gas meter with 80mm or 100mm pipe.
Bet that's cheap. What pressure drop u allowed over length of run?
Customer must love that a 80mm gas running through there house. The costs must also be huge
Pressure Drop of 0.075 kPa.
The costs for gas installations are what they are.
Most domestic houses would have 25mm or 32mm pipe from the meter.
Please note: our pipe sizes are measured OD - I think you guys measure ID.
Our pipe sizes - for copper - are as per the imperial sizes ( Plumbing )
1/2" - 12.7mm OD, 3/4" - 19mm OD, 1" 25.4mm.
You guys seem to mention often 22mm & 28mm pipe.
Which are sizes we are not accustomed to.. unless when doing refrigeration pipework.
Ours go in OD and mm
6,8,10,12,15,22,28,35,42,54
usually any bigger and people start using steel
Reply to Gas Pressures. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath the boiler is difficult with lots of obstacles, is it okay if I run soldered copper over / across the top of the boiler? It'll be about 4" off the top...
