Discuss Gas rates on lpg system? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Illuminate
illuminate
Can somebody tell me how to gas rate on a lpg system longhand on a metric meter?
On a condensing boiler open hot tap so boiler operates at max
Two minutes test
2nd meter reading - 1st meter reading
X 30 = m3/hr? Correct?
Then converting this to kw net?
M3/hr x propane calorific value 95
Then devide that by 3.6 = kw gross ÷ devide by 1.11 to get kw net?
Can some let me know the correct way with lpg?
Reply to Gas rates on lpg system? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
