Discuss GCH pressure = zero in the Plumbing Jobs | The Job-board area at PlumbersForums.net
snadge
Hi
we recently bought a house and have been in for couple of months now - and last night when filling the bath with hot water (which is heated on demand) there was lots of stop/start and banging noises in he pipes - we turned it off then ran it again and it was fine... however we noticed that the presure gauge shows ZERO....
what has happened?
can anybody help with this?
it seems to work still..
cheers
Most sealed systems leak to a degree. Refill the pressurized part to a known pressure and then watch it to see how quickly the pressure drops.
I would have thought your boiler would have a low pressure cutout, though, so I'm surprised it ran when dry...
Reply to GCH pressure = zero in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I recently had an eco tec plus 836 combi installed as part of an oil to gas conversion. One thing I can’t work out is why the bathroom sink hot...
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and...
losing pressure
L
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Hi, I have a hot water cylinder which feeds 3 outlets (kitchen sink, basin in bathroom & bathtap) which has never had very good pressure (probably...
1K
