Discuss Geberit WC Frame feet rotation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just wondering if anyone can see in issue if I rotate one of the feet on a Geberit WC frame through 90 degrees? One would be toed in as supplied the other facing backwards.
If I rotate one foot through 90 I can get a good joist fix and avoid moving some pipework at the same time.
Cheers
No your fine aslong as its not pointing frontwards
Reply to Geberit WC Frame feet rotation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
