Discuss glow worm flexicom 12hx in the Plumbing Jobs | The Job-board area at PlumbersForums.net
at the moment i have 5 radiators 1 double and 4 single panel. they all are 40 odd years old , i want to relace all with double panel ones. would my boiler cope ok ?. it is a condenser boiler and the tank in the loft is open vented. hope some one can give me any advice. thanks.
there ok but i would ignore the warranty, make sure you inspect them for damage tho
Ignore because they're not likely to honour it, or because warranties on rads not likely to be required?
both as they will want system water tests and they will blame it on corrosion
Reply to glow worm flexicom 12hx in the Plumbing Jobs | The Job-board area at PlumbersForums.net
