Discuss Gluing Solvent ABS With Solvent PVC Pressure? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can 40mm solvent ABS (e.g. Floplast) be glued into a 40mm pressure solvent PVC (unknown manufacturer) pipe fitting?
They're both solvent based, the Floplast solvent cement says it can glue both ABS and PVC, but can they be glued together?
You should always use the correct solvent cement for the 'generic' type of system i.e. pressure rated cement for pressure system and it needs to be from or approved by the manufacturer of the pipe/fittings.
What is your application, a gravity waste pipe? If it's anything pressurised I'd say NO.
Reply to Gluing Solvent ABS With Solvent PVC Pressure? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
