Discuss Green copper pipes, plumber didn't clean up flux after job in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I'm currently refurbishing a room. Plumber has been in for first fix to lay new pipework for new radiators.
He's laid fresh copper pipe, however around the joints they are all green which I believe is flux residue he hasn't cleaned up after soldering.
Not the cleanest of jobs but I'm not too fussed from a cosmetic point of view as it won't be on show but is there any risks of corrosion or anything that would warrant him coming back to clean them up?
Thanks all for confirming.
Question now becomes... do I ask him to come back? I noticed it after he left, really I should have inspected it closely and pointed it out before he left so he could have sorted it there and then.
Or do I clean it myself and just mention it to him when he comes back to do second fix? If this option, how would be best to clean it?
It may have just slipped his attention and wasn't green at the time, obviously. I'm sure it happens even to the best of us (except me, of course).
Wet rag for most fluxes. Corroded areas may need a bit of elbow grease. You won't cause harm by cleaning it off.
If he's used a flux like like Fluxite that isn't very water soluble you will need hot water and a good scrub (but Fluxite doesn't turn pipes green so that rules that out).
Reply to Green copper pipes, plumber didn't clean up flux after job in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Sonya K
