Discuss Grundfos hot water pump running continuously in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
chrisj14uk
Hi all,
Hoping you can help... I've recently moved into a new flat and am a bit concerned about the plumbing. There's a continual hum from the airing cupboard, which contains two water pumps (judging from power lead labels, one for heating, one for hot water). The hot water pump is on 24/7... when thermostat and boiler are both powered down.
Is there any reasonable reason why the pump might always be on? I briefly found online hot water circulation systems etc.
Chris
the pump should never run 24/7 unless it is wired wrong or there is a fault
some of the old secondary circulation pumps ran 24/7 just fit a timer
Eco
There's a hot water tank, if that's the same thing...
There are two pumps coming off the hot water tank, only the one labelled 'hot water' is running continuously... so the water in the tank seems to be continually moving too, I'll see if I can upload a photo later this evening
Rory sounds right to me. Think you have a Gledhill boilermate Thermal store. This will run 24-7. Got to keep store at 75 degrees to work
actually thermalc stores should be about 80 degrees...this is your central heating water, the dhw picks it's heat up from here
Reply to Grundfos hot water pump running continuously in the Plumbing Jobs | The Job-board area at PlumbersForums.net
