Discuss Grundfos pump oscillating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
finchy01
Morning chaps,
I've been sent to look at a job. Sealed system with a big twin head self modulating grundfos pump. The pump is constantly modulating up and down, up and down and the pressure is up and down in time with the modulating. I e not worked on this type of pump before (I've been living under a rock for the last couple of years!) And just wondered if you can give me some tips on what to check?
Many thanks as always.
Hi oz. Thanks for replying. It does have a bypass. A manual one which was shut when I arrived on site but opening that does nothing. It's still pulsing. I've check the pump valve too and they are fully open -1/4 turn obviously. It's a grundfos alpha to not a twin head as I was told!
How close to the pump is the by-pass?
The pump could be over compensating itself if the by-pass valve is too close to the pump.
It could also be the same situation with the by-pass closed and the pump pushing water through the TRV's.
The pump may be oversized for the job and is trying to constantly rectify itself to suit demands.
Thanks again oz. The bypass is very close to the pump so I'm liking your theory. It's a 3 floor office bock so I doubt the pump is oversized however I didn't get a chance to have a proper look around as I was being hounded to move onto the next job and arrange a time to go back when we have more time. I will double check the distances. I'm guessing the dial on the front of the pump is similar to the old 3 speeds on 15/50. Surely switching this down would compensate for the pump trying to work top hard?
Reply to Grundfos pump oscillating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
    • Friendly
Hi, I've followed this excellent forum for several years but have never posted, so decided I'd better give some details. My status is the upper...
