Discuss Hairline crack in the Plumbing Jobs | The Job-board area at PlumbersForums.net
darrenangel
I have a hairline crack in the corner of my shower tray. Is there a spray on, or paint on liquid silicone on the market. Normal silicone is too thick to penetrate the crack. Thanks in advance. Darren
Dont bother wasting your money,
MY OWN shower trays have cracked 3 times (3 plastic cheap trays) 1 even 2yrs, they developed a hairline crack which allowed water to pass through
I bought a china enamel tray ( held on a thick wooden base for plenty of support ) its been strong now for the past 4 years
Its like a exhaust of your car, if it gets a crack you can use exhaust putty, it holds for few days then the crack reappears.
Advice and best solution - BUY A NEW TRAY
Good luck mate :)
Any shower tray that's not sufficiently supported will crack over time. I always use 18mm plywood under mine plus sand and cement if it's a stone cast tray.
Ditto, although I usually used cement based flexi adhesive
Yeah I find 1m wbp and flexible tile adhesive are the best, it's defiantly best to go for a new tray
Reply to Hairline crack in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
  • Sticky
We have 2 brand new cordless, battery powered press tools in stock, and flying off the shelves. Our TekTools TZ1930 & TZ1550 are packed with...
