Discuss HALL of SHAME PHOTo`s in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Come across that a lot on stuff fitted in the 70's and 80's. Some that are fully soldered you can snap off easily. Might be a combination of bad cleaning and the flux but it only seems to be on stuff from about a 10 year span. Saying that it is unusual to find soldered copper stuff from the 60's or earlier. It was all compression or paraffin blow lamps for lead then.Take a look at this soldered joint I melted off. Literally holding by a solder thread and all joints seem same. Some of the pipes are also cut at a bad angle, obviously with a hacksaw, (this one in photo is done badly with a pipe cutter) Pipes half in, barely soldered. This is original work (30 years old) on a system now converted to combi high pressure in a flat.
Really shocking "plumbers" could do such consistently useless soldering.
Note the fitting shows bare copper never soldered also. I am removing every fitting above the floor, but it is a worrying thought that the pipes are buried in screed floors. Not a good idea to even move the pipes
Nearer 40 years. The guy who put it in is probably pushing up daisies
not clean enough before soldered
after 30 years its done its job,may be ****e but its held up,move on folks,nothing to see here
Yep found a few of those underfloorFlux joints on gas last well!
Reply to HALL of SHAME PHOTo`s in the Plumbing Jobs | The Job-board area at PlumbersForums.net
