Discuss Harleqin Heatstream 200L Direct Mains Pressure Hot Water Storage Tank 200Dir in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PDS
Hi All,
I’m fitting my first Harlequin unit next week and would appreciate any advice or tips you guys may have.
The installation guide recommended either an expansion vessel or shock arrestor, what would be the preferred unit?
Thanks in advance.
If this is what I think it is , its a thermal store . So should only need a shock arrester or small ex vessel just used on the incoming mains . What do the Mi’s say ?
Reply to Harleqin Heatstream 200L Direct Mains Pressure Hot Water Storage Tank 200Dir in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Is it worth replacing a Potterton gold 9kw electric boiler with a hot water storage tank for a new Electric Combi Boiler ? Would there a...
Low hot water pressure Hi everyone, I'm hoping someone is able to shed some light on my situation before I have to call out the professionals...
M
I have a viessman vitodens 222F combi storage boiler on the ground floor. It has 100l capacity inbuilt cylinder which is delivered on mains...
Max Hill
M
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
