Discuss Has GasSafe changed in the past 2 years? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
acecharly
Hi im looking to re-register shortly and was wondering what has changed in the past 2 years has information on there website improved etc etc?
also are there any new things with which i will need to be brought up to speed on?
Cheers
Cheers
It is not what has changed in the last 2 years but I guess what has changed in the last 7 as that was the last time you took the assessment & quite a lot has. To much to list here but a few highlight's flue in ducts, use of gas analyzers (CPA1 is now in the CCN1).
Best thing is take some training to get you back up to speed.
Cheers
Competence review? It seems that the industry can't decide on whether the exams you pay for make you competent.
APHC sparks debate on gas competency | News | Heating and Ventilation News
In addition there were nearly 6,500 new operatives added to the gas safe register last year, so work will be a little more difficult to come by.
Not to forget the analyser situation - you will need cpa1 and have to buy and calibrate the instrument each year (if you don't already own one).
are you going for reassessment or starting again from scratch
there was a letter in gas safe magazine a few months ago, says nobody ever fails the reassessment, is this true or just an exaggeration, the way it was worded it was as if it was meant to be taken literally
if its so easy to pass makes you wonder whats the point
Reply to Has GasSafe changed in the past 2 years? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Central Heating Pump - G Pump Force HE-RS25/6PWM-130 Hi, I would be grateful if someone could explain whether our CH system can cope with the...
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for...
  • Article
The UK Government has today been told to do better when it comes to Heat Pumps and Hydrogen Boilers. A watchdog for spending has said that the...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
Hi everyone I currently work in oil and gas industry working in North Sea and further afield operating on high pressure oil and gas plants. This...
