Discuss Heat absorber while soldering in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Old Account
hi guys,
I have seen long time ago at plumbase a heat absorber while soldering, it was a red mastic ball or something similar.
However, does anyone remember what to call it ?
Kind regards
Ron
Thank you Shauni,
I definitely meant this product. Just forgot what the name was.
Personally I can't see a use for it. A damp flannel or something similar has always worked a treat for me.
I am not saying it doesn't work surely it does. I am just wanting to remind a mate about it.
And if the water is off/system drained you have to wet it from your own water bottle or dunk it in the crapper
Reply to Heat absorber while soldering in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
