Discuss Heating wont work without DHW on in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
tapsworcester
I have been to a house where the heating won't run unless the DHW is also selected. Can somebody please diagnose this for me?
The system is unvented, the heating is pumped by a Grundfoss, the DHW is gravity fed 28mm pipework. The boiler is an old Mistral oil boiler. The control is a Honeywell 24 hour controller. There are TRV on the radiators.
Thanks for your help.
If on gravity dhw and pumped heating then this is correct, as the dhw calls for boiler to fire and the ch calls for pump to operate. You stated that the system was unvented...
Unvented on gravity hot water! Coil drops inside so can't work very well. Hope there is sufficient control.
Aside that, the clock for Gravity hot water will always bring the rads in too.
Reply to Heating wont work without DHW on in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I...
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring...
1K
Central Heating Pump - G Pump Force HE-RS25/6PWM-130 Hi, I would be grateful if someone could explain whether our CH system can cope with the...
T
Hi We urgently need to get our h/w cylinder replaced because it's leaking. Our current system is oil boiler feeding underfloor downstairs...
