- Messages
- 34,334
- Solutions
- 2
Discuss .....Heatline c24..... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Me either. Don’t all speak at once.
Tried that and nothing. The whole thing goes mental once it starts. It’s actuall really loudGood lord, its not happy for sure. No idea but you may be able to use your hand to feel the vibrations which may be strongest at the component that is vibrating. At least its only the HW cct.. lol
Everything is good. Serviced it whilst there. Regulates down as expected.Sounds like a saw at the timber merchants.
Are all your burner pressures fine ?
Burner clean ? Injectors clean ?
Does it make that noise when it of max gas ?
Cannot see anything and it only does it on hot water.sounds like air getting into the burners like when you purge is the some splits in the burner
thats when its at its highest setting so may be worth checking the burnerCannot see anything and it only does it on hot water.
I will have a look when I go back as it is leaking as well.thats when its at its highest setting so may be worth checking the burner
That’s where I was heading. But wanted other views/ideas.plates in plate heat ex
Reply to .....Heatline c24..... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
