Discuss Heatline Compact S30 pcb in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Petechesh
Hello all, new member and I am hoping someone can help me.
Would anyone have a wiring diagram for a Heatline S30 printed circuit board. I have a failed boiler and having checked the pcb all 240v circuits appear OK, but the low voltage has no output from the transformer. The manufacturers site is basic for this level of information. I would also appreciate someone confirming the low voltage control on the pcb is 24v.
Thanking you in anticipation
Pete
Reply to Heatline Compact S30 pcb in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need some help with a Worcester Junior 28i gas boiler and I'm hoping someone here may have came across this fault before ... I have checked...
1K
Hi, Have a Valliant Ecotec Plus 637 system boiler that is showing no error codes and S.0 (no demand for heat), but it is not heating. Have...
1K
Good Afternoon all, I am hopeful someone may be able to offer some guidance on the following. In the home we have a gas boiler (serviced...
Hello My trusty Vaillant 242 EH is having some issues. It has developed an issue when firing up the burner. The fault is seen with the hot water...
We live in a 1980s four-bedroom detached house. The time has come for new central heating. The current system is a mild revision of the original...
2K
