Hi all, Looking for some advise on the above boiler ,I have been called out to one today diverter block split and main heat ex leaking also actuator and pressure sensor knackered due to water leakage priced up parts, diverter block with prv side included, actuator, pressure sensor, heat ex o rings and plate seals came in at £350. I am not to sure pcb will be okay will have to wait to dry out. First question is can you still buy these boilers !!! . SECOND IS IF NOT. Are the parts off the HEATLINE capriz 24,28 compatible. Many thanks Mark
