Discuss Hello! Help required with re pressurizing boiler please :( in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
fi71
Hello
I need to re pressurize my boiler (Ideal Isar 30) I think I need to turn two
screws, however one of the screws that I thought I needed to turn won't budge, so now I am worried
that it isn't this one at all! I have connected the filling loop and have attached a pic if anyone
could help me with which bits to turn, it would be very much appreciated.
thanks, Fiona
open the left hand side one, then the right hand side one until pressure gauge reads 1-1.2 bar. then turn off both. if you are constantly topping up, you probably have a small leak somewhere
Hi
thanks very much, is it the two main screws on the picture that I have to turn?
Thank you very much for helping so quickly, should one of them be really hard to move?
They can be. Try turning the other way. Don't force it though, nothing good happens from that.
Reply to Hello! Help required with re pressurizing boiler please :( in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a "Firebird Envirogreen Condensing Combi Oil Boiler 26kW" a part has went and I can't find it anywhere, I was at every plumbers merchant...
Hi everyone, New here & my first post! I have a Worcester greenstar 24i, it is a conventional boiler, it has a water tank upstairs. For the...
2K
Hello All. Sorry, im new to the forum and had a quick look around, but I couldnt find any answers. I have an HE35 Isar boiler and over the past...
Hello everyone, I'm facing an issue with my Vaillant EcoTec 832 boiler and would greatly appreciate your expert advice. The Problem: Heating...
Hi, It may be coincidence but not long after getting oil fired central heating fitted to older ex-council property (fireplace and necessary...
SaintSinner
