Discuss Hello, new member, question regarding unvented cylinder installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Darren
Hi
I have recently had a unvented cylinder installed. The old water tank has been replaced with this system at a cost of £2500. Does that sound reasonable?
Darren
sorry its way too hard to say without knowing the full scope of work
Welcome to the forum Darren :)
Too hard to say, need some more info.
What's making you ask the question ?
Welcome!
Thanks for your responses everybody.
I know it's after the event I just wanted to know if I was paying a fair price.
We had 2 old water tanks replaced with this new system that has markedly improved the pressure and regulation of temperature.
It's a tempest cylinder.
Darren , we would still need more info mate , where is the cylinder sited ? Size of cylinder ? Major pipework changes ? Etc etc I could go on , sorry
it sounds like a fair bit of work, also depends on where in the country you are as to what you'll pay.
If it's only water tanks out and cylinder in then somebody has had your eyes out. Did they wear a mask ?
Ok it's positioned in the airing cupboard where the old immersion tank was. Next to the main bathroom, we are having 3 bathrooms redone so there is pipe work for that but it's on a separate quote. He spent at least a couple of days disconnecting the old water tank in the loft
Can you do a few more photo's some of the left hand pipework and more on the top. There are a few issues.
Reply to Hello, new member, question regarding unvented cylinder installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is unvented and pressurised. The cold water feed into this cylinder is from the attic tank, not the mains as I turned off the mains stopcock to see if hot...
Hi All I had an unvented cylinder fitted about 6 years ago. It only supplies hot water to my shower. I was hoping for a much better flow rate from the shower but it seemed no different from the original combi boiler hot feed. There is (unusually) a lever that lets me select the combi or the...
Steveo111
T
Hi We urgently need to get our h/w cylinder replaced because it's leaking. Our current system is oil boiler feeding underfloor downstairs, radiators upstairs and an unvented hot water cylinder for hot water. We are thinking of moving to a heat pump at some point but aren't ready to do this. My...
Hi All, I have recently changed heating source to a heat pump and so I have had a new water cylinder installed (different internal element required). This means that I have a 2.5 year old StainlessLITE Plus Horizontal unvented mains pressure 204L cylinder left over. We had it installed in Jan...
Peter M
Good evening, I'd like your opinion on something that is worrying me please: my landlady's plumber replaced the bottom/night element of my 20-year-old unvented cylinder (an Ariston Classico HE STD 150) 5 days ago and I hadn't noticed that it was leaking. He fixed the leak today but now the...
