Discuss Help/advice please... (Grant) Kerosine boiler question in the Oil and Solid Fuel Forum area at PlumbersForums.net
Deleted member 113095
My regular plumber is a good guy but getting reponse from my regular plumber (and the previous one) where I live is rubbish at the best of times. And in the current climate, getting anyone else is proving (understandably) impossible
The valve, circled in white in the attached pic is leaking. Perhaps irt need a new washwer/seal but is it someting that can be done by me/DIY if I turn water off at mains, once pressure has dipped (due to lack of demand, i.e. overnight) to zero, and leak stops. Valve is always set fully open, and is obviously designed so it can be closed during servicing or whatever.
I keep having to periodically repressuriize the system, and keeping it at around 0.5 (usualy it hovers just above 1.0 bar.
Thanks in advance for any help/advice/suggestions
Due to the current situation you'll struggle to find someone to come out unless it's an essential repair and seeing as you're making do I doubt someone will, this is troubling times for everyone.
Is the drip coming from the nut that tightens to pump or the spindle? If it's around the nut you'd probably get away with a new washer but if it's around the spindle then I'd replace the whole valve. If that's the case it will require draining down and replacing and refilling but as I said above trapped air in combis can cause a lot of ball ache.
Get adjustable spanner or simple spanner to fit last nut properly, then tighten it very gently. Watch drips, count it per minute, see if it slows down. Last nut tightens spindle in place , it is small and brass, use gentle force.
If the leak is coming from the spindle the gland nut can be tightened and if that doesn't work the gland can be repacked quite easily and without draining down.
OP, is it leaking from up around the spindle, from around that nut that sits around the spindle, or somewhere else?
Reply to Help/advice please... (Grant) Kerosine boiler question in the Oil and Solid Fuel Forum area at PlumbersForums.net
Hi, Firstly, I am neither plumber nor heating engineer, just a willing diy, have a go guy. I have a Grant 26 oil fired combi boiler which started...
3K
Hello everyone, I hope you can help..I'm a total dunce when it comes to all things plumbing, apologies if posted in the incorrect forum too...
3K
  • Locked
We purchased an incomplete house 2 years ago. It was a bargain so we were prepared for possible unpleasant surprises. So far the only major...
2K
  • Locked
please can someone help me a little. I am a council tennant and was placed on a scheme that involves getting GSH installed, first of all the...
2K
  • Locked
Hello there, would be very grateful to get some help on my copper pipe dilemma. With reference to the attached image, when unscrewing the valve...
1K
Dotty
