Discuss Help getting access to the mechanism of this tap please. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, can anyone advise regarding getting access to the working mechanism within this tap. It's leaking and I want to change the washer. There's no grub nut around the base and as can be seen there's no access via the top of the tap. I'm thinking that the top skirt will unscrew with the help of a wrench and some protection but I don't want to try that until I get some confirmation advice from you guys. Ta
Probably undo the shroud and the top will come off as one rubber gloves might help you grip it
Reply to Help getting access to the mechanism of this tap please. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
Sonya K
