Discuss Help !! Grant Vortex 36 Outdoor Boiler - Nightmare....Not firing up in the Plumbing Jobs | The Job-board area at PlumbersForums.net
SMH13
Hello
I feel I know almost everything about my Grant Vortex Combi Condensing boiler !
In fact Grant replaced my first one a couple of years ago as there were so many problems !!
Well it must have been 3 months that its been working and now no hot water or heating.
There is power, pressure is fine, oil fine......however, usually when I switch it on and off (taking the cover off) it fires up.
Now it makes a whooshing noise like its about to fire up and nothing.
Any help would be really appreciated :confused5:
lcome to the forum, grant technical are normally very good, try to contact
Does the burner repeatately try to fire up without going to lockout ? The photocell may be dirty or oil pump is broken, would be my best first guesses, but either way, you are better getting it looked at & prob serviced.
I have the same problem. The boiler will sound as if it has started and I can hear the pump working but the boiler is not firing. If I switch the boiler off and on it will eventually fire up. The warm water store is not working, so the only way for us to get warm water is when the heating is on??? Nightmare!!!
SOunds like a PCB ranbru, the latest versions are more robust, though recently I have been swapping the control panel out for the latest 'e' model, as I have to date had zero problems with them.
Reply to Help !! Grant Vortex 36 Outdoor Boiler - Nightmare....Not firing up in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Any advice welcome as plumber stumped Had 36-46 grant vortex utility boiler 7 years no problem recently oil tank move and tigerloop install...
Hi, I have an issue with my Grant Vortex internal combi boiler. Specifically the electrical side. Everything was working fine (with a dual...
1K
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer...
Hi there. I have Grant oil fired boiler which when cold, takes multiple times to fire up. It will run for say 20 or 30 seconds with hot exhaust...
R
Evening everyone, We've been having some issues with hot water coming from our Grant Vortex 21 boiler (external, oil fired, no cylinder) Water...
1K
