FixTheBog is a one stop destination for all your toilet spares, such as Flush Valves, Toilet Push Buttons, Toilet Cistern levers, Shower Engines, Temperature Controls, Shower Hoses and Shower Heads. If your bathroom needs fixing then FixTheBog is the place to shop.
Recently had one and swapped the cistern out for a new one (low level with flush pipe). The nuts that are in the pan actually leak if removed so they need to be kept if you do the same. You may even be able to raise that cistern and do the same, mine had cracked because the nocturne had dropped and the weight of the water on the screws killed it
Reply to Help identify an unusual toilet piece in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
