Discuss Help locating isolating valve in the Ireland area at PlumbersForums.net
OK. Thanks for responding. I guess i just need to turn off the water at the mains ?There aren’t any there just compression elbows
Yes, tanks in the loft and cylinderhows your hot water made ? Combi , cylinder
do you have tanks in your loft ?
Thank you. No bathroom sinkIs the tap in question the kitchen tap ?
Thank you for respondingbest option would be to turn the main off then open the bath hot if you have a bath if not kitchen hot will do wait until it stops then open the basin taps should be nothing coming out / should stop
Reply to Help locating isolating valve in the Ireland area at PlumbersForums.net
