Discuss Help needed on central heating problem in the Canada area at PlumbersForums.net
Evening gents
I have a Worcester green star ri controlled by a Honeywell st9420c controller and wireless thermostat
All working fine this morning now when home from work I’m getting no heating. The light is on on the controller and the digital thermostat is showing the fire symbol but there’s no heating working at all
Hot water is heating up apparently fine and the boiler will periodically fire up and then stop again about 10 seconds later
Any ideas? Had a new grundfos pump and switch fitted 18 months ago
Thanks a lot in advance
Do you have a hot water cylinder and zone valves as below ? It may be a faulty head on the heating valve it may be possible to lock the head open its a common fault the motor may be burnt out or the linkage worn so not triggering the micro switch when it moved over . Kop
Reply to Help needed on central heating problem in the Canada area at PlumbersForums.net
