Discuss Help please Alkathene 21 to copper15 mm reducer leaking hissing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hope pic worked this is leaking was just wondering if they need replacing after so long leaking at top over the white insert
Any help appreciated
Looks like a bodge up white part shouldn't be visible, replace whole fitting using the correct adaptor to copper pipe.
:D needs replacing also needs a copper transition sleeve/piece in the top and not a normal 20mm insert
Ok I'll go and try and get a replacement tomorrow could this get worse like blow off while I'm in bed lol I'll turn water off from outside if that's the case
Many thanks for replys
Yes it could and agree turn the water off outside
Lol must have been when house was built 11 years ago I don't no what it's meant to look like just thought it shouldn't be leaking
On the black gunked up part to says 21-15 Universal
Can't see much else down hole don't think it's 25mm copper pipe looks flexi
20mm alk then you have two options either buy a reducing / conversion set (like in the second link I posted) or buy a new 20-15mm alk fitting
Short bit of 15mm from the elbow to the new / conversion and an 15mm copper olive and your golden
Reply to Help please Alkathene 21 to copper15 mm reducer leaking hissing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
