Discuss Help. Should there be a vent pipe after the boiler and before the pump. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
richiepg
I think my heating system is sucking air in through vent pipe.
My heating system is as follows, boiler, pump, motorised valves then I think the vent pipe is after these. Does this sound wrong. I've taken a picture but Iam having trouble uploading it. Thanks
That's a sealed system man- prv on the boiler. Must be an expansion vessel????
If it is open vent you got trouble coz the vent will connected after the valves or somewhere by your hwc off the return!
Cheers man, Iam new to the house. I think it was a sealed system converted to open vent as there is a tank in the loft. Also there is a back boiler stove in the house. Iam thinking of disconnecting the back boiler(getting a plumber) and going back to sealed. Would this stop air getting into the rads.
Thanks I'll get a plumber out, I just wanted to get a better understanding before I called someone. Appreciate it man
Reply to Help. Should there be a vent pipe after the boiler and before the pump. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi thank you for letting me join this forum . We have an air to water heat pump but the bungalow is piped in micro bore 10mm pipe which doesn’t...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
Hello. I am planning to build a small half bath in my garage, next to a washing machine, using old showers plumbing. There was a stand-alone...
Hi. I recently had a renovation done. My builder installed a new Combi boiler instead of my system boiler. He connected the pipework to the...
Dear professionals, could someone kindly advise on per below issue, please let me know if more pictures or details needed. I think my Auto Air...
