Discuss Help with identifying a shower runner in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
chris corkill
Can anyone help with a query. I have moved into a new house and one of the runners on the shower door is broken. There is no name on the shower doors or the runner so i cannot identify what make it is. The only info is PA6 30007CH if anyone can help with the make and where I could get a new runner that would be great.
picture is detailed below
Can U post a picture? I may have the odd one knocking about here I could sell you.
Many of the door runners are generic. You could start by trying one of the bathroom centres (such as the Plumb Center bathroom shop).
Hee Chris, i have the same problem Did you find a new runner somewhere because i dont know where to buy one.
Thanks,
Bob
Hello Chris,
Did you ever get a spare runner? I have the same problem, being that one of the bottom peg runners has a split in it.
Mark
Thanks,
Bob
Hello Bob,
Did you ever find a replacement part? I have the same problem.
Mark
Sounds like an opportunity to create a fix for this then?!
there is a company called showerdoorrollers.co.uk that stocks many obsolete parts
give them a look up
Already different posts on the same subject however Yes useful intel none the less.
Reply to Help with identifying a shower runner in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
