Discuss Help with installing American Purchased Tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
cylon007
We purchased a Delta Pilar Touch2O faucet and brought it into the UK to use in our new kitchen here. Our plumber told us that he would be able to install it after looking at the technical information but once he tried he realised that the threads in the US are different to in the UK.
I looked through the tech documents for this tap and can see that the water comes in through a 3/8"-24 UNEF fitting. I have been googling now for way too long trying to find something that would convert a UNEF thread into the 15mm BSP thread that is used in the UK and simply can't find anything. Has anyone got any information or pointers that could help me out?
Many thanks for any help that you can give me at all.
You will need a brass fitting which goes from your 3/8"-24 UNEF down to 1/2" NPSC (or NPT) male. Then you need a standard 1/2" BSP female x 15mm coupling to get to your 15mm pipe.
A 1/2" NPSC (or NPT) will just about go into a 1/2" BSP as the thread pitch is the same.
Alternatively if you can get a 3/8"-24 UNEF down to 1/2" copper compression it would do.
You probably want an engineers merchants rather than a plumbers merchants.
You could look online for a US dealer. Otherwise do you have any friends in the US who could send you one?
Post a picture. I may even have something here which would do your job - I have some spare US fittings which came with some catering stuff.
Otherwise have a look on fleabay! Allsorts there you may get lucky!
Such fittings do exist - it's just a matter of finding where to get them from!
You can only get 1/2" NPT or NPSC to marry up with BSP as it is only 1/2" size which have the same number of teeth per inch (14).
These guys may have something or may be able to point you in the right direction:
[DLMURL="http://www.coleparmer.co.uk/products/fittings/fittings.asp"]Tubing Connecters, Pipe Connectors and Fittings from Cole-Parmer[/DLMURL]
I think you may have written it down wrong - 3/8 - UNF is 24 teeth per inch and 3/8 UNEF - is 32 teeth per inch (Unified National Extra Fine btw). I would be very doubtful if the thread is UNEF as this is mainly used for precision equipment - the thread pitch is less than 1mm!
You can only marry up 1/2" NPT or NPSC to BSP as only 1/2" have the same number of teeth per inch (14).
That is what also confused me - from the little research I did a UNEF thread should be 32, and not the 24 (which is UNF). However, the technical document from Delta definitely says 3/8"-24 UNEF. You can find the document linked below.
Product Documentation : Customer Support : Delta Faucet
I have also attached a photograph of the ends of the pipes.
I found an adapter in the States supplied by Delta (the guys who made the tap) to take the 3/8" UNEF to 1/2 NPT - so hopefully this will solve my problem!
Thank you everyone for your help!
Easy way to tell - you can count the teeth per inch!
As to compatibility of NPSM and NPSC with BSP I can't say for sure but make sure you have 14 teeth per inch. The Americans have so many different thread sizes.
If I remember rightly from my pipefitting days npt or anpt (american national pipe thread) is the same as bsp upto 2" after that it is compleatly different.
Eco
Eco
I agree on the 2" bit but just to correct the npt bit as its means national pipe taper i.e.
BSP - British standard Pipe
BSPT - British standard pipe taper
For the oil Guys
UNF - Unified national Fine
UNC - Unified Nation course
WHPES is spot on with the 14 TPI (threads per inch) I`m glad that its not just me who`s full of carp -- No offence ;)
For the oil Guys
WHPES is spot on with the 14 TPI (threads per inch) I`m glad that its not just me who`s full of carp -- No offence ;)[/QUOTE
I hang my head in shame!
Simple answer to your original problem, put the taps on e bay and buy uk standard fittings, surley their are some you like on one of the sheds.
Not all the thread sizes and pitches are the same between NPT and BSPT, so be careful. 1/2" is the same. I think 3/8" has different numbers of threads per inch.
Reply to Help with installing American Purchased Tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
