Discuss Help with tap pipe fittings in the USA area at PlumbersForums.net
Hi, can somebody help me with a link or a name of the fitting I need to be able to connect this pipe to the tails of the taps
thanks in advance
Reply to Help with tap pipe fittings in the USA area at PlumbersForums.net
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of...
Hello, I need some advise, will greatly appreciate if someone can help. My mixer tap is leaking from base want to renew it. However the tap...
Hi. Could somebody recommend a Muslim shower valve that does not leak please? Or one that has a washer that you can replace if it leaks? Some...
Help / advice please? I have attached pics I want to fit a new basin tap. The new tap came with flexible hose. Q1. Pic 1 - the fitting into the...
Hi everyone I hope you can help. We were getting some work done and our builder attached the boiler condensate pipe to the sink waste pipe. This...
