Discuss Help with tap? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Davalan
Hi
I wonder if anyone could help me with a simple problem please.
The upper part of my sink tap has come loose and I can't figure out how to get to the nut/screw to tighten it. It looks as though the top cap should come off but it doesn't want to and I don't want to force it. It's a Bristan tap. I have searched the web to try to solve the problem but no joy.
Photo attached.
A strap wrench might help you unscrew the top chromed part.
The wrench if you don't know is really just a rubber strap on a handle and don't cost much.
It did the job for me on similar taps that the top bit had well seized. Anything else would have damaged the top
Thanks all for the reply's. The chrome cap is perfectly smooth so I can't grip it. It's certainly not loose. I'll get hold of a wrench as Best has suggested and give that a try.
Thanks Again.
Or if you first try using gloves as Alex suggested and still no luck, then try putting a few turns of electrical insulating tape just around the top part, making the tape a bit randomly overlapping and lumpy to aid a really good grip
have worked on that type before but can't remember,so if it doesn't come off as said above,get a small screwdriver and see if the top flips off or the brass bit unscrews clockwise or it the whole head just pulls off, let us know please, might need some grips.
pretty certain that the above is correct, the top chrome cap screws off with difficulty. 10+ year old Bristan Omega Taps me thinks
SOLUTION
I tried a strap wrench but it kept slipping off. In the end an old adjustable wrench was able to get some bite on an edge and the chrome cap unscrewed anticlockwise as was thought. See Photo.
Thanks for all the help.
Glad you finally got the top off. I also found the strap wrench to slip off the rounded top piece, but I kept trying it numerous times until I unscrewed it.
When you refit the top piece, or any of the head parts, use a dab of Vaseline or silicone grease on the threads and spindle end, etc. That way, it will all come apart for some lucky person next time.
Reply to Help with tap? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
