Discuss Hep2o to radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
Ktm640
Hi All,
I am in the process of fitting a new central heating system to our house.
I intend to run the flow and return pipes in Hep2o but wanted some advice on connecting to the radiators.
Would you always connect to the rads in copper? I have read you can take 15mm Hep2o branches off the flow and returns to the rads but would you recommend taking it all the way or change to copper before final connection to the rads?
Thanks in advance.
Steve
Change to copper before the final connections to the radiators.
Plastic looks horrible and it bends when it's hot - which makes it look even worse.
I thought that might be the case. Our house has solid floors downstairs so I will be changing to copper just above the ceiling and dropping the legs down the walls in copper. For the upstairs I will be using short risers in copper from just below the floorboards.
That's the plan at the moment anyway.
Can you see any issue with using plastic between the floor and ceiling void and copper where it's visible?
Many Thanks
Many Thanks
I see no problems, this is the normal practise..
Reply to Hep2o to radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
