Pilch
Hi all, now a member of another forum. I have a small problem, hopefully. My head is spinning having searched the web for answers and now I am confused. I have a Glow worm Micron boiler downstairs and on the landing cupboard I have an indirect hot water cylinder which we have just replaced in the same position. I have also replaced the thermostat on the side and also replaced the 3 port mid-position-valve. Having refilled the system and tried it on heating and hot water together it was fine, I was unaware of any noises. But now when I turn on hot water on its own after about 20 minutes I hear gurgling/running/dripping water through the pipes around the cylinder and when I stand by the boiler. Then after about 3 minutes of the noise the boiler will shut off (reset). I am assuming this is trapped air and have tried releasing it through the release valve which is on the end of the pipe pointing upwards from the mid-pos-valve. I get an instant release of water/hiss but I'm not sure whether I should be doing this when it makes the noise and whether I should be pushing on it continually. Any suggestions on what to do next. Thanks
