Discuss Hive on Potterton Boiler in the Central Heating Forum area at PlumbersForums.net
Might be of interest, - note post #7 in the thread below
My (not researched thoroughly so read the above) understanding is that you wire the Hive L and N to the boiler supply L and N, and then the Hive programming outputs supply mains L (eg from terminal 4 to CHr etc.)
5 core or two 3 cores 0.75 or 1mm2 is fine
Absolutely amazing. So so helpful and well laid out answer. Thank you. I did search at the beginning but definately didn't find this post. Perfect thank you.
Just need to confirm if 1mm flex would be ok for the job?
Perfect. Thank you.
Definitely not questioning you but where does the fifth come in?
Constant live
Constant neutral
Switched CH live
switched HW live
?? Earth? But does it need an earth as the hive box only has a 'tether' and is not earthing it?
It's only that I have some 4 core at home, if not I'll go out and get some 5.
You need an earth at each appliance hence the earth point even though it’s a class 2 fitting eg all plastic exterior
Reply to Hive on Potterton Boiler in the Central Heating Forum area at PlumbersForums.net
Hi, I am trying to link a Hive heating & hot water dual channel receiver to an old Vaillant THERMOcompact VU GB 242/1 E system boiler. It has an...
My disabled daughter’s hot water has stopped working. It’s a relatively modern Potterton boiler with an indirect sealed hot water system and a...
Hi I’m looking to install the above. Atm I have an older one fitted (old wireless thermostat and old receiver that’s wired into my combi boiler...
Hi everyone, i was looking for advice on what hive I need to buy. my daughter bought a new build house and she want to switch the existing...
Hi I seek some advice on replacing an existing regular boiler. I currently have an old Potterton 10-16 Netaheat electronic, which is around 35...
