Discuss Hot Water For Bathing Ideas in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I live in an apartment with a cold water tank. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my bathroom, and according to the plumber who fitted the new taps, high-pressure taps were fitted. Consequently, the water from taps is of a low volume and rate. I wonder if the main water supply could supply them? Please let me know if this is possible. The plumber who fitted them said there was a reason it could not be done, but I can’t remember what he said. There appears to be no good reason for the cold water tank. If it helps, the apartment was built in 1986.
I also wish to dispense with the immersion heater, but I am interested in installing a device that would provide instant hot water for a bath, handwashing, or shaving.
If you have any questions, ask away. Hopefully, I can answer them.
L.
Sounds like you need to install / have installed is a unvented water heater eg mains pressure
Hi!
install an instantaneous water heater, but you need a certain water pressure
Reply to Hot Water For Bathing Ideas in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hello, We hade a problem with our hot water not working in one of our bathroom's (all other outlets were working) Therefore we got the...
Hi I have a 22mm hot and cold water supply to new bath. The pipes finish with compression valves. I need a 500 mm tap connector hose to connect...
I live in an apartment and have a cold water tank in it. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I...
