Discuss How can i remove the end of the tap to clean filter in the USA area at PlumbersForums.net
Lai
Purchased swirl minimalist mixer basin tap - how can I clean the aerator at the end of the tap?
Usually the end of the spout unscrews revealing a filter /swirler inside.
The part below the arrow
You may have to turn the tap on after removing the spout end to force the filter out.
Rubber gloves give a better grip or a pair of these but because it is plastic go easy with the pressure applied.
Should you destroy it new ones can be found if you know the size.
Reply to How can i remove the end of the tap to clean filter in the USA area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
